Einleitung
This guide will show you how to replace the trackpad on the HP 15-dy2024nr. A trackpad detects the motion and position of a user's fingers, and translates them to a position on the screen.
To indicate whether your trackpad needs replacing, it will show signs of:
- Touch not being registered.
- Unable to click.
- Lag.
- Dents and/or scratches.
- If liquid is spilled on it.
- Heating up.
Was du brauchst
Use a spudger to peel one corner of each of the rubber feet from the bottom of the laptop.
Gently peel the feet from the laptop using the spudger revealing the screws underneath.
Use a Phillips #1 screwdriver to remove:
Two 2.5mm x 6mm screws
Six 2mm x 6mm screws
Insert an iFixit opening tool into the seam between the keyboard area and bottom cover.
Using another iFixit opening tool, slide along the seam to unhook the clips.
When the front of the laptop is open, you can use your finger to hold a corner open then slide an iFixit opening tool along the seam toward the back corner.
After the clips have been released, flip the laptop over and lift the cover.
Remove five 2.0mm x 3.0mm screws using a Phillips #00 screwdriver.
Use the iFixit opening picks to lift the battery away from the laptop.
Unplug the battery from the motherboard.
Lift the battery away from the laptop and remove.
Remove two 3.0 mm screws using a Phillips #1 screwdriver.
Lift the metal bracket away from the laptop and remove it with your hands.
