Zum Hauptinhalt wechseln
HP 15-dy2702dx Battery Replacement
Was du brauchst
  1. HP 15-dy2702dx Battery Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Remove both of the rubber strips to uncover the hidden screws.
    • You can use a prying tool to help lift an end.
  2. HP 15-dy2702dx Battery Replacement: Schritt 2, Bild 1 von 1
    • Unscrew all 8 Phillips #0 screws on the bottom panel:
    • Two M2.5x6
    • Six M2x6
  3. HP 15-dy2702dx Battery Replacement: Schritt 3, Bild 1 von 2 HP 15-dy2702dx Battery Replacement: Schritt 3, Bild 2 von 2
    • Flip the laptop over and open the lid.
    • Separate the bottom panel from the main body by using the iFixit opening tool.
    • Ensure that the bottom panel is completely separated along the edges.
  4. HP 15-dy2702dx Battery Replacement: Schritt 4, Bild 1 von 2 HP 15-dy2702dx Battery Replacement: Schritt 4, Bild 2 von 2
    • If you can lift the laptop like shown in the first picture, the bottom panel is nearly separated.
    • Close the laptop to allow the back edges to fully separate
  5. HP 15-dy2702dx Battery Replacement: Schritt 5, Bild 1 von 3 HP 15-dy2702dx Battery Replacement: Schritt 5, Bild 2 von 3 HP 15-dy2702dx Battery Replacement: Schritt 5, Bild 3 von 3
    • Flip the laptop over and carefully remove the lower case.
  6. HP 15-dy2702dx Battery Replacement, Battery: Schritt 6, Bild 1 von 2 HP 15-dy2702dx Battery Replacement, Battery: Schritt 6, Bild 2 von 2
    • Remove the five M2x6 screws that secure the battery with a Phillips #0 screwdriver.
  7. HP 15-dy2702dx Battery Replacement: Schritt 7, Bild 1 von 3 HP 15-dy2702dx Battery Replacement: Schritt 7, Bild 2 von 3 HP 15-dy2702dx Battery Replacement: Schritt 7, Bild 3 von 3
    • Grab the sides of the battery and gently pull the battery until it disconnects from the connector on motherboard.
    • Lift the battery up and out.
Abschluss
September Oo
397 Reputation
4 Anleitungen geschrieben
Gateway, Team 1-4, Pee Fall 2023 Mitglied von Gateway, Team 1-4, Pee Fall 2023
GCC-PEE-F23S1G4
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 57
Insgesamt: 349
