Einleitung
This guides explains how to replace the keyboard on your HP 15-dy2072dx. A replacement may be needed in cases the keyboard stops functioning. Before replacing the keyboard, make sure the problem cannot be solved by replacing a single key.
The keyboard allows the user to enter text, use specific functions, make use of shortcuts.
This guide uses prerequisite guides and each guide will show parts that may have been removed in previous steps still attached. Ignore the discrepancy and focus on each steps taken.
Was du brauchst
Flip the laptop over and open the lid.
Separate the bottom panel from the main body by using the iFixit opening tool.
Remove the five M2x6 screws that secure the battery with a Phillips #0 screwdriver.
Grab the sides of the battery and gently pull the battery until it disconnects from the connector on motherboard.
Lift the battery up and out.
Lift the black ribbon covering the screws.
Unscrew the top three M2x3 Phillips screws.
Flip up the locking flap holding the trackpad ribbon in place.
Pull the ribbon straight out of its socket.
Locate the storage drive.
Unscrew the single screw holding the drive in place.
Use a Phillips #0 screwdriver to unscrew the three screws that secure the fan.
Grip the cord that connects the fan to the motherboard and gently pull out to disconnect the cable from the connector.
Peel off the black sticker covering the silver connectors near the top of the motherboard.
Remove the two silver colored round connector from the motherboard by pulling them up.
Pull up on the last connector on the motherboard next to the connectors removed in the previous step.
Unscrew the three M2x6 Phillips screws from the left metal hinge.
Lift the hinge.
Remove the black boxes from the case.
Disconnect the power cable (white cable with a black flag at the end).
