Zum Hauptinhalt wechseln
HP 15-ef2025nr Fan Replacement
Was du brauchst
  1. HP 15-ef2025nr Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop upside down with the hinge facing you.
  2. HP 15-ef2025nr Fan Replacement: Schritt 2, Bild 1 von 2 HP 15-ef2025nr Fan Replacement: Schritt 2, Bild 2 von 2
    • Use an opening tool to remove the rubber strips by prying up a corner and gently pulling off the strip.
  3. HP 15-ef2025nr Fan Replacement: Schritt 3, Bild 1 von 2 HP 15-ef2025nr Fan Replacement: Schritt 3, Bild 2 von 2
    • Use a Phillips screwdriver to remove the eight 3 mm screws (including the 2 screws that were not under the rubber strips) securing the lower case.
  4. HP 15-ef2025nr Fan Replacement: Schritt 4, Bild 1 von 2 HP 15-ef2025nr Fan Replacement: Schritt 4, Bild 2 von 2
    • Flip the laptop over and open the lid.
    • Insert an opening tool into the seam between the edge of the lower case and the chassis.
    • Gently pry around the entire perimeter until the lower case separates from the chassis.
    • Close the lid and flip the laptop back over.
    • Remove the lower case.
  5. HP 15-ef2025nr Fan Replacement: Schritt 5, Bild 1 von 3 HP 15-ef2025nr Fan Replacement: Schritt 5, Bild 2 von 3 HP 15-ef2025nr Fan Replacement: Schritt 5, Bild 3 von 3
    • Remove the five 2 mm Phillips screws holding the battery down.
    • Take care not to puncture, bend, or twist the battery. Lithium batteries can be very volatile. Follow all proper hazardous disposal laws where you live.
    • Gently lift the front edge of the battery up to disconnect the socket.
    • Lift the battery up and out.
  6. HP 15-ef2025nr Fan Replacement, Fan: Schritt 6, Bild 1 von 3 HP 15-ef2025nr Fan Replacement, Fan: Schritt 6, Bild 2 von 3 HP 15-ef2025nr Fan Replacement, Fan: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to pull the fan connector directly out of its motherboard socket.
    • Do not pull on the wires; they are very delicate.
  7. HP 15-ef2025nr Fan Replacement: Schritt 7, Bild 1 von 3 HP 15-ef2025nr Fan Replacement: Schritt 7, Bild 2 von 3 HP 15-ef2025nr Fan Replacement: Schritt 7, Bild 3 von 3
    • Remove the three 2 mm Phillips screws at the top corners and four o'clock position on the fan.
    • Remove the fan.
Abschluss
kyle mccomas
291 Reputation
2 Anleitungen geschrieben
Austin Community College, Team 1-1, Watkins Spring 2023 Mitglied von Austin Community College, Team 1-1, Watkins Spring 2023
AUSTINCC-WATKINS-S23S1G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 11
Letzte 30 Tage: 19
Insgesamt: 182
