Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide explains how to remove the RAM chip from the HP 15-f009wm notebook computer. This could be done to either replace a malfunctioning chip or to upgrade to a larger chip.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Turn laptop upside down. Flip the lock switch to the unlocked setting.
    • Turn laptop upside down.
    • Flip the lock switch to the unlocked setting.
  2. Flip the release switch. Once the flip is switched, the battery should pop out. Once the flip is switched, the battery should pop out.
    • Flip the release switch.
    • Once the flip is switched, the battery should pop out.
  3. Slide the battery out. Slide the battery out.
    • Slide the battery out.
  4. Das Essential Toolkit
    Die nützlichsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  5. Remove the two Phillips #1 screws from the RAM panel. Remove the two Phillips #1 screws from the RAM panel. Remove the two Phillips #1 screws from the RAM panel.
    • Remove the two Phillips #1 screws from the RAM panel.
  6. Use the plastic opening tool to pop the panel off. Use the plastic opening tool to pop the panel off. Use the plastic opening tool to pop the panel off.
    • Use the plastic opening tool to pop the panel off.
  7. Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM. These tabs lock the chip in place and releasing them will cause the chip to "pop" up. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  8. Remove the RAM chip from the laptop.
    • Remove the RAM chip from the laptop.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Alex Birchler
877 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S2-G2, Nance Spring 2018 Mitglied von USF Tampa, Team S2-G2, Nance Spring 2018
USFT-NANCE-S18S2G2
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 2
Letzten 30 Tage: 11
Insgesamt: 271
