Zum Hauptinhalt wechseln
HP 15-f162dx Hard Drive Replacement
Was du brauchst
  1. HP 15-f162dx Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Place the laptop upside down on a hard flat surface.
    • Slide the right release latch to unlock the battery.
    • Slide the left release latch to release the battery.
    • Lift the battery up and away from the computer.
  2. HP 15-f162dx Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • You will need a small Phillips screwdriver for this step.
    • Loosen the two screws holding on the laptops service door.
    • You do not need to remove the screws from the door. Just loosen them enough to be able to separate the service door from the main body of the laptop.
    • Lift and slide the service door out of the body of the laptop.
  3. HP 15-f162dx Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Remove the small screw holding in the optical drive.
    • Carefully slide the optical drive out of the laptop and set it aside.
  4. HP 15-f162dx Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • You will need a Phillips screwdriver and spudger for this step.
    • Remove the center screw near the battery slot.
    • Open the lid of the laptop and set it on its side. Insert a spudger into the same hole the screw was removed from.
    • Push the spudger inward until the keyboard is disengaged. Once disengaged, flip the laptop upright.
  5. HP 15-f162dx Hard Drive Replacement: Schritt 5, Bild 1 von 2 HP 15-f162dx Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Make sure the laptop is sitting upright with the lid open.
    • Slide your finger under the keyboard along the top edge of the keyboard to release the keyboard.
    • Swing the keyboard away from the screen and rest it on its face.
    • Image Two
    • Release the ZIF connecter by lifting the connector tab connected to the keyboard cable.
    • Disconnect the keyboard cable.
    • Remove the keyboard.
  6. HP 15-f162dx Hard Drive Replacement: Schritt 6, Bild 1 von 2 HP 15-f162dx Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • This step will require a Phillips screwdriver.
    • Remove the screws that were underneath the keyboard.
    • Image Two
    • Disconnect the three cables that were underneath the keyboard.
    • Close the laptop lid and flip the laptop upside down.
  7. HP 15-f162dx Hard Drive Replacement: Schritt 7, Bild 1 von 3 HP 15-f162dx Hard Drive Replacement: Schritt 7, Bild 2 von 3 HP 15-f162dx Hard Drive Replacement: Schritt 7, Bild 3 von 3
    • You will need a Phillips screwdriver and the jimmy for this step.
    • Remove the screws shown.
    • Image Two
    • Flip the laptop right side up and open the lid.
    • Image Three
    • Insert the jimmy in between the top cover and the base and slide it along the edge of the laptop. Repeat for the opposite edge.
    • Swing the upper left and upper right corners away from the screen and lift the top cover away from the laptop.
  8. HP 15-f162dx Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • You will need a Phillips screwdriver for this step.
    • Flip open the ZIF connecter on the USB/Audio cable. Disconnect the USB/Audio cable.
    • Unscrew the screw shown.
    • Lift out the USB/Audio board.
  9. HP 15-f162dx Hard Drive Replacement: Schritt 9, Bild 1 von 3 HP 15-f162dx Hard Drive Replacement: Schritt 9, Bild 2 von 3 HP 15-f162dx Hard Drive Replacement: Schritt 9, Bild 3 von 3
    • Lift the end of the hard drive that is along the side edge of the laptop.
    • Slide the hard drive out.
    • Image Two
    • Disconnect the cable attached to the hard drive.
    • Image Three
    • Remove the hard drive bracket from the old hard drive.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 17
Letzte 30 Tage: 51
Insgesamt: 3,318
