Einleitung
If you need to open your HP 15-g029wm to access its internal components, this guide will show you the process of removing the laptop's top plate. If you're encountering problems with your device such as overheating, freezing, random shutdowns, or needing to replace a component, you might refer to this guide. This guide can also be used if you need to remove the keyboard of your laptop.
Was du brauchst
Unplug any charging cord or accessories connected to the device before beginning.
Remove the following Phillips screws on the lower case:
Nine 5 mm
One 6 mm
Use an opening pick to remove the two circular rubber feet near the laptop hinges.
Remove both of the 8 mm Phillips screws.
Use an opening pick to pry up and remove the left hinge cover.
Use an opening pick to pry up and remove the right hinge cover.
Flip the device face up and open the lid.
Insert an opening pick under the keyboard and pry around the perimeter of the keyboard until it fully releases.
Lift the keyboard slightly.
Use your fingers or an opening pick to unlock the ZIF locking flap that secures the keyboard ribbon cable.
Disconnect the keyboard ribbon cable.
Lift the keyboard off.
Remove two 5 mm screws using a Phillips screwdriver.
Insert an opening pick in the seam between the top case and chassis.
Slide the opening pick around the edge of the device to separate the top case from the chassis.
Slightly lift the top case up and away from the chassis.
Use your fingers or an opening pick to flip up the black ZIF locking flap.
Disconnect the ribbon cable.
Lift off the top case.
