Zum Hauptinhalt wechseln
HP 15-g071nr Hard Drive Replacement
Was du brauchst
  1. HP 15-g071nr Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 HP 15-g071nr Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the laptop over so the bottom is facing upwards.
  2. HP 15-g071nr Hard Drive Replacement: Schritt 2, Bild 1 von 2 HP 15-g071nr Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Press the tabs at the corners of the laptop at the same time to release the battery.
  3. HP 15-g071nr Hard Drive Replacement: Schritt 3, Bild 1 von 3 HP 15-g071nr Hard Drive Replacement: Schritt 3, Bild 2 von 3 HP 15-g071nr Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Pull the battery away from the laptop in one motion.
  4. HP 15-g071nr Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Using your Phillips #0 screwdriver, remove all of the screws on the back case.
  5. HP 15-g071nr Hard Drive Replacement: Schritt 5, Bild 1 von 3 HP 15-g071nr Hard Drive Replacement: Schritt 5, Bild 2 von 3 HP 15-g071nr Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Carefully move the iFixit opening tool along the seam of wrist rest until you can remove it.
    • Remove the wrist rest once it comes loose from the body.
  6. HP 15-g071nr Hard Drive Replacement: Schritt 6, Bild 1 von 3 HP 15-g071nr Hard Drive Replacement: Schritt 6, Bild 2 von 3 HP 15-g071nr Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Remove the two screws with the Phillips #0.
    • Gently pull the hard drive out of its SATA connection to the motherboard.
    • Attach the loose data cable to the new drive.
    • Be careful not to damage the silver ribbon cable below the hard drive itself.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 1,029
