Einleitung
You can use this guide to help you safely and effectively remove the front panel, or the housing cover, from your HP 15-r137wm TouchSmart device. Be sure to follow all steps in order to ensure proper removal of components and connections. This guide is a prerequisite for all guides of this device, since it is required to remove the housing to access the components.
Was du brauchst
Remove all ten (10) 5.5 mm Phillips #0 screws.
Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
Use a wide plastic opening tool to pry off the top casing.
Lift the cover off carefully as there are wires still attached to internal components.
Move the keyboard slightly out of the way to locate the connection.
Disconnect the small wire protruding from the motherboard underneath the metal plate.
Locate the connection between the power button and the connecting cable.
Remove the cable from the motherboard carefully.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
