Einleitung
During the process, be careful with the placement of removed screws. This back panel disassembly is required to access all internal components.
Was du brauchst
Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
5 weitere Personen haben diese Anleitung absolviert.
