Einleitung
Use this guide to replace the hard drive in your HP 17-bs049dx.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
Remove screw (7.51mm) on USB port with "Phillips 0 Screwdriver".
Lift the USB port over and away from hard drive.
Lift rubber black tabs located on the hard drive upwards.
Disconnect hard drive from motherboard by pulling towards you.
5 weitere Nutzer haben diese Anleitung absolviert.
2 Kommentare
How much force am I required to put while lifting the back panel to access the internal components? I can go hulk on it but then I wouldn’t have a laptop later…
