Zum Hauptinhalt wechseln
HP 17-bs049dx RAM Replacement
Was du brauchst
  1. HP 17-bs049dx RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • To remove the battery, simply push the tabs towards each other.
    • The battery will come out with force, be sure to keep anything fragile away from the laptop during this process.
  2. HP 17-bs049dx RAM Replacement, Back Panel: Schritt 2, Bild 1 von 1
    • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
    • Rubber tabs will require force to access screws.
  3. HP 17-bs049dx RAM Replacement: Schritt 3, Bild 1 von 1
    • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
  4. HP 17-bs049dx RAM Replacement: Schritt 4, Bild 1 von 2 HP 17-bs049dx RAM Replacement: Schritt 4, Bild 2 von 2
    • Pull outwards on the disk reader to remove from main frame.
    • This removal will require force.
    • All screws must be removed before removing disk reader.
  5. HP 17-bs049dx RAM Replacement: Schritt 5, Bild 1 von 1
    • Lift back panel to access internal components.
    • You will need to use force to pry it open.
  6. HP 17-bs049dx RAM Replacement, RAM: Schritt 6, Bild 1 von 2 HP 17-bs049dx RAM Replacement, RAM: Schritt 6, Bild 2 von 2
    • To take off the RAM, pull out the circled taps in the direction of the arrows on the pictures.
    • You will have to gently force it out to avoid breaking it.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Megan Paige
457 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 7
Insgesamt: 766
