Zum Hauptinhalt wechseln
HP 17-bs049dx USB Port Replacement
Was du brauchst
  1. HP 17-bs049dx USB Port Replacement, Battery: Schritt 1, Bild 1 von 1
    • To remove the battery, simply push the tabs towards each other.
    • The battery will come out with force, be sure to keep anything fragile away from the laptop during this process.
  2. HP 17-bs049dx USB Port Replacement, Back Panel: Schritt 2, Bild 1 von 1
    • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
    • Rubber tabs will require force to access screws.
  3. HP 17-bs049dx USB Port Replacement: Schritt 3, Bild 1 von 1
    • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
  4. HP 17-bs049dx USB Port Replacement: Schritt 4, Bild 1 von 2 HP 17-bs049dx USB Port Replacement: Schritt 4, Bild 2 von 2
    • Pull outwards on the disk reader to remove from main frame.
    • This removal will require force.
    • All screws must be removed before removing disk reader.
  5. HP 17-bs049dx USB Port Replacement: Schritt 5, Bild 1 von 1
    • Lift back panel to access internal components.
    • You will need to use force to pry it open.
  6. HP 17-bs049dx USB Port Replacement, USB Port: Schritt 6, Bild 1 von 2 HP 17-bs049dx USB Port Replacement, USB Port: Schritt 6, Bild 2 von 2
    • Remove the two screws using a Phillips #0 screwdriver.
  7. HP 17-bs049dx USB Port Replacement: Schritt 7, Bild 1 von 3 HP 17-bs049dx USB Port Replacement: Schritt 7, Bild 2 von 3 HP 17-bs049dx USB Port Replacement: Schritt 7, Bild 3 von 3
    • At both ends of the connector ribbon, unclip both connectors.
    • Gently remove the ribbon from the unlatched area.
Abschluss
Logan McCarty
307 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 265
