Zum Hauptinhalt wechseln
HP 17-x027ds Wifi Card Replacement
Was du brauchst
  1. HP 17-x027ds Wifi Card Replacement, WiFi Card: Schritt 1, Bild 1 von 3 HP 17-x027ds Wifi Card Replacement, WiFi Card: Schritt 1, Bild 2 von 3 HP 17-x027ds Wifi Card Replacement, WiFi Card: Schritt 1, Bild 3 von 3
    • Flip the laptop so you can see the serial number and the four 7mm screws in all the corners.
    • Click the hinges by pushing them inward, which are located at the top.
    • Remove the battery by pulling it out.
  2. HP 17-x027ds Wifi Card Replacement: Schritt 2, Bild 1 von 3 HP 17-x027ds Wifi Card Replacement: Schritt 2, Bild 2 von 3 HP 17-x027ds Wifi Card Replacement: Schritt 2, Bild 3 von 3
    • Remove the 2 pieces of black tape that are each covering a 7mm screw at the top corners of the laptop.
    • When removing the 2 black pieces of tape, keep the tape so you can place it back on the laptop again when reassembling.
    • Remove the fourteen 7mm screws with a JIS #00 screwdriver.
  3. HP 17-x027ds Wifi Card Replacement: Schritt 3, Bild 1 von 2 HP 17-x027ds Wifi Card Replacement: Schritt 3, Bild 2 von 2
    • Lift the bottom cover of the laptop with a metal spudger by wedging the sides first and going all around.
    • The cover is difficult to lift, so use extreme force.
  4. HP 17-x027ds Wifi Card Replacement: Schritt 4, Bild 1 von 3 HP 17-x027ds Wifi Card Replacement: Schritt 4, Bild 2 von 3 HP 17-x027ds Wifi Card Replacement: Schritt 4, Bild 3 von 3
    • Carefully pull the two cables attached to the CPU.
    • They are labeled 1 and 2. When putting the cables back, make sure to put them in the correct section.
    • Remove the screw holding down the CPU with the same screwdriver tip as before.
    • Gently pull on the CPU to remove it.
Abschluss
Tyrin
188 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 361
