Einleitung
The RAM is essential to access and retrieve memory on a device. A faulty RAM might cause problems while using your computer. This guide will show you how to replace the RAM.
Was du brauchst
Locate all 8mm screws on the back of the computer and remove them with the Phillips #1 screwdriver.
Once you remove the back panel, locate the RAM.
Use your fingernails to release the clips holding the memory by pulling them away from the RAM.
4 weitere Personen haben diese Anleitung absolviert.
