Was du brauchst
The left side of the spacebar key will start lifting up. At this point you can remove the spacebar key.
you will notice a metal bars along the rim these metal bars is what connects the bottom surface together.
slide the bracket into the space below the spacebar to carefully place it back.
The Spacebar key will be working once you can press down and it will type a space.
Fast fertig!
Abschluss
