Zum Hauptinhalt wechseln
HP 17-x173dx CPU Cooling Fan Replacement
Was du brauchst
  1. HP 17-x173dx CPU Cooling Fan Replacement, Battery: Schritt 1, Bild 1 von 2 HP 17-x173dx CPU Cooling Fan Replacement, Battery: Schritt 1, Bild 2 von 2
    • Begin by sliding the left tab to the unlock position
  2. HP 17-x173dx CPU Cooling Fan Replacement: Schritt 2, Bild 1 von 1
    • Push each of the two tabs in the direction specified by the picture.
  3. HP 17-x173dx CPU Cooling Fan Replacement: Schritt 3, Bild 1 von 3 HP 17-x173dx CPU Cooling Fan Replacement: Schritt 3, Bild 2 von 3 HP 17-x173dx CPU Cooling Fan Replacement: Schritt 3, Bild 3 von 3
    • Slide and hold the right tab to the left, while gently pushing out the battery with your thumbs
  4. HP 17-x173dx CPU Cooling Fan Replacement, CPU Cooling Fan: Schritt 4, Bild 1 von 2 HP 17-x173dx CPU Cooling Fan Replacement, CPU Cooling Fan: Schritt 4, Bild 2 von 2
    • Use a spudger or Jimmy to lift the plastic back cover starting from the back right side near the vents.
    • Remove the back cover of the device by continuing to lift the plastic around the entire perimeter of the device.
  5. HP 17-x173dx CPU Cooling Fan Replacement: Schritt 5, Bild 1 von 3 HP 17-x173dx CPU Cooling Fan Replacement: Schritt 5, Bild 2 von 3 HP 17-x173dx CPU Cooling Fan Replacement: Schritt 5, Bild 3 von 3
    • Using the Phillips #0 screwdriver, unscrew four heat-sink screws (These will unscrew, but will stay attached to the heat-sink), and one screw towards the top.
    • Disconnect the power cable.
  6. HP 17-x173dx CPU Cooling Fan Replacement: Schritt 6, Bild 1 von 2 HP 17-x173dx CPU Cooling Fan Replacement: Schritt 6, Bild 2 von 2
    • Remove the CPU cooling fan.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 385
