Zum Hauptinhalt wechseln
HP 17t-k000 Series Display Panel Replacement
Was du brauchst
  1. HP 17t-k000 Series Display Panel Replacement, Display Panel: Schritt 1, Bild 1 von 2 HP 17t-k000 Series Display Panel Replacement, Display Panel: Schritt 1, Bild 2 von 2
    • If the screen is cracked or otherwise severely damaged, apply painter's tape (or a light adhesive tape) over the screen to protect yourself and the laptop.
  2. HP 17t-k000 Series Display Panel Replacement: Schritt 2, Bild 1 von 1
    • Make sure that the laptop is completely powered off. The power light should remain off.
    • Disconnect all cables and external devices from the laptop.
  3. HP 17t-k000 Series Display Panel Replacement: Schritt 3, Bild 1 von 2 HP 17t-k000 Series Display Panel Replacement: Schritt 3, Bild 2 von 2
    • Close the laptop and flip it over.
  4. HP 17t-k000 Series Display Panel Replacement: Schritt 4, Bild 1 von 3 HP 17t-k000 Series Display Panel Replacement: Schritt 4, Bild 2 von 3 HP 17t-k000 Series Display Panel Replacement: Schritt 4, Bild 3 von 3
    • Slide the battery release latches toward the center of the laptop.
    • Remove the battery.
  5. HP 17t-k000 Series Display Panel Replacement: Schritt 5, Bild 1 von 2 HP 17t-k000 Series Display Panel Replacement: Schritt 5, Bild 2 von 2
    • Remove the rubber feet on each corner cover with a plastic spudger or plastic opening tool.
  6. HP 17t-k000 Series Display Panel Replacement: Schritt 6, Bild 1 von 3 HP 17t-k000 Series Display Panel Replacement: Schritt 6, Bild 2 von 3 HP 17t-k000 Series Display Panel Replacement: Schritt 6, Bild 3 von 3
    • Remove the following screws from the back case and corner covers:
    • Eighteen 6 mm Phillips #0 screws
    • Two 7 mm Phillips #0 screws
    • If you do not have a magnet that can lift the screws out, you may have to turn the laptop over until each screw drops into your hand.
    • Do not proceed unless all the screws are out! You can severely damage your keyboard in the following steps if you still have a screw in place.
  7. HP 17t-k000 Series Display Panel Replacement: Schritt 7, Bild 1 von 3 HP 17t-k000 Series Display Panel Replacement: Schritt 7, Bild 2 von 3 HP 17t-k000 Series Display Panel Replacement: Schritt 7, Bild 3 von 3
    • Lift the corner covers out with a plastic spudger or plastic opening tool.
  8. HP 17t-k000 Series Display Panel Replacement: Schritt 8, Bild 1 von 3 HP 17t-k000 Series Display Panel Replacement: Schritt 8, Bild 2 von 3 HP 17t-k000 Series Display Panel Replacement: Schritt 8, Bild 3 von 3
    • Remove the optical drive cover with a spudger or plastic opening tool.
    • Remove the two 2 mm Phillips #00 optical drive screws.
  9. HP 17t-k000 Series Display Panel Replacement: Schritt 9, Bild 1 von 2 HP 17t-k000 Series Display Panel Replacement: Schritt 9, Bild 2 von 2
    • Turn the laptop over and open the lid.
  10. HP 17t-k000 Series Display Panel Replacement: Schritt 10, Bild 1 von 3 HP 17t-k000 Series Display Panel Replacement: Schritt 10, Bild 2 von 3 HP 17t-k000 Series Display Panel Replacement: Schritt 10, Bild 3 von 3
    • Begin prying up the keyboard at a front corner of the laptop with a plastic opening tool.
    • Continue prying up the keyboard, working your way toward the other front corner and then along the sides.
    • Don't lift the keyboard out yet when it separates from the frame. It still has cables attached on its underside!
    • It is normal to hear loud pops and clicks at this step.
  11. HP 17t-k000 Series Display Panel Replacement: Schritt 11, Bild 1 von 3 HP 17t-k000 Series Display Panel Replacement: Schritt 11, Bild 2 von 3 HP 17t-k000 Series Display Panel Replacement: Schritt 11, Bild 3 von 3
    • Disconnect the four ribbon cables that come from the underside of the keyboard.
    • To release each ribbon cable, gently pry up the retention clamp with a fingernail or plastic spudger to a 90 degree angle. Then, pull the cable out.
    • Double-check that all cables connecting the keyboard to the base of the laptop have been completely disconnected before removing the keyboard.
    • Lift the keyboard up and set it to the side.
  12. HP 17t-k000 Series Display Panel Replacement: Schritt 12, Bild 1 von 1
    • Turn the laptop so that it rests on the top cover.
    • This prevents the laptop from falling over when you are not holding it.
  13. HP 17t-k000 Series Display Panel Replacement: Schritt 13, Bild 1 von 2 HP 17t-k000 Series Display Panel Replacement: Schritt 13, Bild 2 von 2
    • Starting at a corner, pry up the screen with a plastic pry tool.
    • Continue around the screen until the screen has completely separated from the top cover.
    • Don't insert the tool more than necessary along the top of the screen, or you may damage a small circuit board located in that area.
    • Don't lift the screen away from the computer yet. There are still cables connected!
    • It is normal to hear some loud pops and clicks at this step.
  14. HP 17t-k000 Series Display Panel Replacement: Schritt 14, Bild 1 von 1
    • Open the laptop to its full extension.
    • Do not force the laptop open farther than it can with minimal force. This can damage the screen, hinges, and internal components!
  15. HP 17t-k000 Series Display Panel Replacement: Schritt 15, Bild 1 von 3 HP 17t-k000 Series Display Panel Replacement: Schritt 15, Bild 2 von 3 HP 17t-k000 Series Display Panel Replacement: Schritt 15, Bild 3 von 3
    • Release the primary display ribbon cable by gently prying up the retention clamp to a 90 degree angle.
    • Pull out the smaller sliding connector next to it.
    • Be gentle when handling the display cable, and be sure to pull the connectors straight out of their sockets.
  16. HP 17t-k000 Series Display Panel Replacement: Schritt 16, Bild 1 von 3 HP 17t-k000 Series Display Panel Replacement: Schritt 16, Bild 2 von 3 HP 17t-k000 Series Display Panel Replacement: Schritt 16, Bild 3 von 3
    • Gently pry the hinges away from the bottom mount.
    • It is normal to hear two loud clicks as these come away.
  17. HP 17t-k000 Series Display Panel Replacement: Schritt 17, Bild 1 von 2 HP 17t-k000 Series Display Panel Replacement: Schritt 17, Bild 2 von 2
    • Gently lift the screen, bezel, and backlight panel out by the hinges.
    • Set them down so that the internal components face up.
  18. HP 17t-k000 Series Display Panel Replacement: Schritt 18, Bild 1 von 3 HP 17t-k000 Series Display Panel Replacement: Schritt 18, Bild 2 von 3 HP 17t-k000 Series Display Panel Replacement: Schritt 18, Bild 3 von 3
    • Carefully peel up the tape securing the connector on the back of the display panel.
    • Remove the connector from its socket by carefully pulling straight back on the tape.
    • If the flat part of the cable is stuck to the display panel, slowly pull it up to break the adhesive.
  19. HP 17t-k000 Series Display Panel Replacement: Schritt 19, Bild 1 von 3 HP 17t-k000 Series Display Panel Replacement: Schritt 19, Bild 2 von 3 HP 17t-k000 Series Display Panel Replacement: Schritt 19, Bild 3 von 3
    • Follow the display cable back toward the hinge cover, carefully pulling it up from the routing channel as you go.
    • Don't pull hard on the cable. If you have trouble getting it to come out of the channel, try pulling or even pushing from a different angle.
  20. HP 17t-k000 Series Display Panel Replacement: Schritt 20, Bild 1 von 1
    • Lift the display cable up and fold it out of the way.
    • If part of the cable is stuck to the display panel, slowly pull up on it to release the adhesive.
    • Be careful not to dislodge the circuit board next to the display panel while moving the display cable.
    • During reassembly, make sure that the small circuit board at the top of the display is properly seated on its two plastic pins.
  21. HP 17t-k000 Series Display Panel Replacement: Schritt 21, Bild 1 von 2 HP 17t-k000 Series Display Panel Replacement: Schritt 21, Bild 2 von 2
    • Remove the six 3 mm Phillips #00 screws from the backlight frame.
  22. HP 17t-k000 Series Display Panel Replacement: Schritt 22, Bild 1 von 2 HP 17t-k000 Series Display Panel Replacement: Schritt 22, Bild 2 von 2
    • Lift the backlight panel out and replace it.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 16
Insgesamt: 1,602
