Zum Hauptinhalt wechseln
HP 550 Notebook LCD Display Replacement
Was du brauchst
  1. HP 550 Notebook LCD Display Replacement, LCD display: Schritt 1, Bild 1 von 1
    • Remove the battery
  2. HP 550 Notebook LCD Display Replacement: Schritt 2, Bild 1 von 3 HP 550 Notebook LCD Display Replacement: Schritt 2, Bild 2 von 3 HP 550 Notebook LCD Display Replacement: Schritt 2, Bild 3 von 3
    • Remove the 8 pads and the underlying screws
  3. HP 550 Notebook LCD Display Replacement: Schritt 3, Bild 1 von 3 HP 550 Notebook LCD Display Replacement: Schritt 3, Bild 2 von 3 HP 550 Notebook LCD Display Replacement: Schritt 3, Bild 3 von 3
    • Use a thin tool to separate the lcd frame
    • Unhook the cover on the 2 hinges on the upper side
  4. HP 550 Notebook LCD Display Replacement: Schritt 4, Bild 1 von 3 HP 550 Notebook LCD Display Replacement: Schritt 4, Bild 2 von 3 HP 550 Notebook LCD Display Replacement: Schritt 4, Bild 3 von 3
    • Remove the LCD cover with delicacy, paying attention to the wires and removing any adhesive if present.
    • Remove 4 lcd fixing screws on one side and 4 screws on the other
    • Force the back cover slightly to access the last screw on both sides
  5. HP 550 Notebook LCD Display Replacement: Schritt 5, Bild 1 von 3 HP 550 Notebook LCD Display Replacement: Schritt 5, Bild 2 von 3 HP 550 Notebook LCD Display Replacement: Schritt 5, Bild 3 von 3
    • Disconnect the lcd panel connector
    • Gently lay the LCD panel on the keyboard.
    • Disconnect video display connector.
  6. HP 550 Notebook LCD Display Replacement: Schritt 6, Bild 1 von 1
    • Remove the LCD panel and replace with the new one
Abschluss
To reassemble the device, follow these instructions in reverse order.
3 weitere Personen haben diese Anleitung absolviert.
it en
100%
Hier starten ›
Smilzo
12.083 Reputation
39 Anleitungen geschrieben
2 Kommentare zur Anleitung
what are those two things on top labeled 1 and 2 in the last picture?
Vladut Prcsina - Antwort
Non ho capito la domanda. Grazie
Smilzo -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 2,679
