Zum Hauptinhalt wechseln
HP 7 1800 Battery Replacement
Was du brauchst
  1. HP 7 1800 Battery Replacement, Remove the back panel: Schritt 1, Bild 1 von 2 HP 7 1800 Battery Replacement, Remove the back panel: Schritt 1, Bild 2 von 2
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Battery Replacement, Remove the battery: Schritt 2, Bild 1 von 3 HP 7 1800 Battery Replacement, Remove the battery: Schritt 2, Bild 2 von 3 HP 7 1800 Battery Replacement, Remove the battery: Schritt 2, Bild 3 von 3
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
TMD
765 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 4-1, Brown Winter 2015 Mitglied von USF Tampa, Team 4-1, Brown Winter 2015
USFT-BROWN-W15S4G1
4 Mitglieder
14 Anleitungen geschrieben
2 Kommentare
This is the OEM Replacement Battery, 740963-001, HP Spare: 739691-001, but you can find an OEM replacement the fits and works perfectly will be the Dell Venue 7 battery -17.29Wh 4550 mAh P708 DHM0J and half the price.
Santiago - Antwort
Santiago is wrong, you cannot use the Dell battery because the connectors are different sizes. Now I am stuck with a Dell battery that does not fit and have to order the hp battery. Also you cannot de-pin the two and re-pin, the brass fitting on the wire are bigger and will not fit in the hp connector. DON NOT TRY USING THE DELL IN PLACE OF THE HP.
Glenn Wemmer - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 3,341
