Zum Hauptinhalt wechseln
HP 7 1800 Motherboard Replacement
Was du brauchst
  1. HP 7 1800 Motherboard Replacement, Remove the back panel: Schritt 1, Bild 1 von 2 HP 7 1800 Motherboard Replacement, Remove the back panel: Schritt 1, Bild 2 von 2
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Motherboard Replacement, Remove the battery: Schritt 2, Bild 1 von 3 HP 7 1800 Motherboard Replacement, Remove the battery: Schritt 2, Bild 2 von 3 HP 7 1800 Motherboard Replacement, Remove the battery: Schritt 2, Bild 3 von 3
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
  3. HP 7 1800 Motherboard Replacement, Remove the large ribbon cable: Schritt 3, Bild 1 von 2 HP 7 1800 Motherboard Replacement, Remove the large ribbon cable: Schritt 3, Bild 2 von 2
    • Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
  4. HP 7 1800 Motherboard Replacement, Remove the smaller ribbon cable: Schritt 4, Bild 1 von 2 HP 7 1800 Motherboard Replacement, Remove the smaller ribbon cable: Schritt 4, Bild 2 von 2
    • Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
  5. HP 7 1800 Motherboard Replacement, Unscrew the 7 silver screws from the logic board: Schritt 5, Bild 1 von 1
    • Remove the following 7 screws:
    • Six 4.17mm Phillips #00 around the motherboard.
    • One 2.67mm Phillips #00 next to the front facing camera.
    • The 2.67mm screw circled in yellow is notably shorter than the other 6 screws circled in red.
  6. HP 7 1800 Motherboard Replacement, Unplug the front facing camera from the logic board: Schritt 6, Bild 1 von 1
    • Gently pry the front facing camera plug up and off of the motherboard.
  7. HP 7 1800 Motherboard Replacement, Remove the logic board: Schritt 7, Bild 1 von 1
    • Carefully lift the motherboard directly up.
Abschluss
TMD
765 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 4-1, Brown Winter 2015 Mitglied von USF Tampa, Team 4-1, Brown Winter 2015
USFT-BROWN-W15S4G1
4 Mitglieder
14 Anleitungen geschrieben
Ein Kommentar
After replacing the motherboard, will is act as a brand new tablet upon next boot? Will the OS and everything already be installed? Or is the main memory module elsewhere in the tablet?
jakehittinger - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 932
