Einleitung
This guide will aid you in the replacement of your HP 7 1800 speaker. It requires beginning soldering skills.
Was du brauchst
Carefully insert a Spudger into one of the corners of the tablet.
Slide the Spudger along the edge popping the tabs out along the way.
Slide the Spudger under the battery to lift it off the adhesive.
Gently pull the cable connection from the motherboard using tweezers.
Desolder the two leads of the speaker wire that are connected to the motherboard.
Using tweezers, gently pull the speaker off of the metal plate.
