Zum Hauptinhalt wechseln
HP 7 1800 Speaker Replacement
Was du brauchst
  1. HP 7 1800 Speaker Replacement, Remove the back panel: Schritt 1, Bild 1 von 2 HP 7 1800 Speaker Replacement, Remove the back panel: Schritt 1, Bild 2 von 2
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Speaker Replacement, Remove the battery: Schritt 2, Bild 1 von 3 HP 7 1800 Speaker Replacement, Remove the battery: Schritt 2, Bild 2 von 3 HP 7 1800 Speaker Replacement, Remove the battery: Schritt 2, Bild 3 von 3
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
  3. HP 7 1800 Speaker Replacement, Desolder the speaker wires: Schritt 3, Bild 1 von 1
    • Desolder the two leads of the speaker wire that are connected to the motherboard.
  4. HP 7 1800 Speaker Replacement, Remove the speaker: Schritt 4, Bild 1 von 1
    • Using tweezers, gently pull the speaker off of the metal plate.
    • The speaker is held onto the metal plate with light adhesive. It will require a little force to peel off.
Abschluss
TMD
765 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 4-1, Brown Winter 2015 Mitglied von USF Tampa, Team 4-1, Brown Winter 2015
USFT-BROWN-W15S4G1
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 9
Insgesamt: 212
