Zum Hauptinhalt wechseln
HP 7 PLUS 1301 Battery Replacement
Was du brauchst
  1. HP 7 PLUS 1301 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 HP 7 PLUS 1301 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure the device is off and not plugged in before starting.
    • Using the Torx T5 screwdriver, remove the 3mm screws on all 4 corners of the device.
  2. HP 7 PLUS 1301 Battery Replacement: Schritt 2, Bild 1 von 2 HP 7 PLUS 1301 Battery Replacement: Schritt 2, Bild 2 von 2
    • Using the plastic opening tool, push in between the front, then slide it around.
    • Slide the plastic opening tool all the way around the tablet to separate the back cover.
    • Be careful when trying to remove the back as the screen can be damaged with excessive force.
  3. HP 7 PLUS 1301 Battery Replacement: Schritt 3, Bild 1 von 2 HP 7 PLUS 1301 Battery Replacement: Schritt 3, Bild 2 von 2
    • Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
    • Remove the back cover.
  4. HP 7 PLUS 1301 Battery Replacement: Schritt 4, Bild 1 von 2 HP 7 PLUS 1301 Battery Replacement: Schritt 4, Bild 2 von 2
    • Push out the connector to disconnect the battery.
    • Move the battery connector clear of the connector socket.
  5. HP 7 PLUS 1301 Battery Replacement: Schritt 5, Bild 1 von 1
    • Carefully remove the battery by sliding a plastic spudger under the battery. Use an adhesive remover if available under the battery to make it easier for the battery to come off.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Adanna Ilori
301 Reputation
2 Anleitungen geschrieben
UC Davis, Team S20-G6, Lore Winter 2019 Mitglied von UC Davis, Team S20-G6, Lore Winter 2019
UCD-LORE-W19S20G6
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 21
Insgesamt: 749
