Einleitung
The battery might need to be changed if the device does not power up, or does not charge anymore. The most challenging step to changing the battery is removing the back cover. The tools listed (or similar) are necessary for the battery replacement.
Was du brauchst
Using the Torx T5 screwdriver, remove the 3mm screws on all 4 corners of the device.
Using the plastic opening tool, push in between the front, then slide it around.
Slide the plastic opening tool all the way around the tablet to separate the back cover.
Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
Remove the back cover.
Push out the connector to disconnect the battery.
Move the battery connector clear of the connector socket.
Carefully remove the battery by sliding a plastic spudger under the battery. Use an adhesive remover if available under the battery to make it easier for the battery to come off.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
