Zum Hauptinhalt wechseln
HP 7 PLUS 1301 Speaker Replacement
Was du brauchst
  1. HP 7 PLUS 1301 Speaker Replacement, Speaker: Schritt 1, Bild 1 von 2 HP 7 PLUS 1301 Speaker Replacement, Speaker: Schritt 1, Bild 2 von 2
    • Make sure the device is off and not plugged in before starting.
    • Use the Torx T5 screwdriver and remove the 3mm screws on all four corners of the device.
  2. HP 7 PLUS 1301 Speaker Replacement: Schritt 2, Bild 1 von 2 HP 7 PLUS 1301 Speaker Replacement: Schritt 2, Bild 2 von 2
    • Using the plastic opening tool, push in between the front, then slide it around.
    • Slide the plastic opening tool all the way around the tablet to separate the back cover.
    • Be careful when trying to remove the back as the screen can be damaged with excessive force.
  3. HP 7 PLUS 1301 Speaker Replacement: Schritt 3, Bild 1 von 2 HP 7 PLUS 1301 Speaker Replacement: Schritt 3, Bild 2 von 2
    • Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
    • Remove the back cover.
  4. HP 7 PLUS 1301 Speaker Replacement: Schritt 4, Bild 1 von 2 HP 7 PLUS 1301 Speaker Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using tweezers, carefully remove the speaker connector from the socket.
  5. HP 7 PLUS 1301 Speaker Replacement: Schritt 5, Bild 1 von 3 HP 7 PLUS 1301 Speaker Replacement: Schritt 5, Bild 2 von 3 HP 7 PLUS 1301 Speaker Replacement: Schritt 5, Bild 3 von 3
    • Insert a spudger in the bottom right of the speaker. It makes the speaker easier to come off.
    • Carefully remove the speaker with your hand.
    • Some force needs to be applied here due to the adhesive on the other side of the speaker.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Shao-Hung Hsiao
201 Reputation
1 Anleitung geschrieben
UC Davis, Team S20-G6, Lore Winter 2019 Mitglied von UC Davis, Team S20-G6, Lore Winter 2019
UCD-LORE-W19S20G6
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 121
