Zum Hauptinhalt wechseln
HP 7 Plus 1302 Power and Volume Button Replacement
Was du brauchst
  1. HP 7 Plus 1302 Power and Volume Button Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Power and Volume Button Replacement: Schritt 2, Bild 1 von 2 HP 7 Plus 1302 Power and Volume Button Replacement: Schritt 2, Bild 2 von 2
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Power and Volume Button Replacement: Schritt 3, Bild 1 von 2 HP 7 Plus 1302 Power and Volume Button Replacement: Schritt 3, Bild 2 von 2
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Power and Volume Button Replacement, Power and Volume Button: Schritt 4, Bild 1 von 1
    • Locate the power and volume buttons on the right side
  5. HP 7 Plus 1302 Power and Volume Button Replacement: Schritt 5, Bild 1 von 2 HP 7 Plus 1302 Power and Volume Button Replacement: Schritt 5, Bild 2 von 2
    • Pop out the power and volume buttons with your hands
Abschluss
IUPUI, Team 1-4, Baechle Spring 2017 Mitglied von IUPUI, Team 1-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G4
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 276
