Zum Hauptinhalt wechseln
HP 8 1401 Battery Replacement
Was du brauchst
  1. HP 8 1401 Battery Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
  2. HP 8 1401 Battery Replacement: Schritt 2, Bild 1 von 1
    • Insert the tip of a plastic opening tool in the seam between the front and back panels.
  3. HP 8 1401 Battery Replacement: Schritt 3, Bild 1 von 2 HP 8 1401 Battery Replacement: Schritt 3, Bild 2 von 2
    • Slide the plastic opening tool around all edges of the device until the back panel detaches.
    • Lift off the back panel.
  4. HP 8 1401 Battery Replacement, Battery: Schritt 4, Bild 1 von 2 HP 8 1401 Battery Replacement, Battery: Schritt 4, Bild 2 von 2
    • Using a spudger or your fingers, disconnect the power cable by sliding the connector out of the socket on the motherboard.
  5. HP 8 1401 Battery Replacement: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    Kaufen
    • Using a plastic card or a nylon spudger, carefully pry the battery from the adhesive on the tablet.
    • Do not use a metal spudger, which may damage/puncture the battery and pose a hazard.
  6. HP 8 1401 Battery Replacement: Schritt 6, Bild 1 von 1
    • Once the battery is removed the battery and tablet should look like this.
Abschluss
Katie Presz
641 Reputation
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 881
