Einleitung
This guide is helpful if you need to replace a dead or damaged battery. Be careful when removing the battery to not bend or puncture it because it may contain hazardous chemicals.
Was du brauchst
Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
Insert the tip of a plastic opening tool in the seam between the front and back panels.
Slide the plastic opening tool around all edges of the device until the back panel detaches.
Lift off the back panel.
Using a spudger or your fingers, disconnect the power cable by sliding the connector out of the socket on the motherboard.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Using a plastic card or a nylon spudger, carefully pry the battery from the adhesive on the tablet.
