Zum Hauptinhalt wechseln
HP 8 1401 Front-Facing Camera Replacement
Was du brauchst
  1. HP 8 1401 Front-Facing Camera Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
  2. HP 8 1401 Front-Facing Camera Replacement: Schritt 2, Bild 1 von 1
    • Insert the tip of a plastic opening tool in the seam between the front and back panels.
  3. HP 8 1401 Front-Facing Camera Replacement: Schritt 3, Bild 1 von 2 HP 8 1401 Front-Facing Camera Replacement: Schritt 3, Bild 2 von 2
    • Slide the plastic opening tool around all edges of the device until the back panel detaches.
    • Lift off the back panel.
  4. HP 8 1401 Front-Facing Camera Replacement, Front-Facing Camera: Schritt 4, Bild 1 von 1
    • Place the tip of your spudger under the edge of the press fit connector, and pry the connector straight up from its socket.
  5. HP 8 1401 Front-Facing Camera Replacement: Schritt 5, Bild 1 von 2 HP 8 1401 Front-Facing Camera Replacement: Schritt 5, Bild 2 von 2
    • Lift the front-facing camera out of the tablet.
  6. HP 8 1401 Front-Facing Camera Replacement: Schritt 6, Bild 1 von 1
    • After the front-facing camera has been removed, the tablet should look like this.
Abschluss
Katie Presz
641 Reputation
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 125
