Zum Hauptinhalt wechseln
HP Beats Special Edition 15-p390nr Battery Replacement
Was du brauchst
  1. HP Beats Special Edition 15-p390nr Battery Replacement, Battery: Schritt 1, Bild 1 von 2 HP Beats Special Edition 15-p390nr Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn computer off before starting.
    • Turn the computer over and slide the battery latch to the left to help partially release the battery.
    • The battery latch is symbolized with a battery icon.
  2. HP Beats Special Edition 15-p390nr Battery Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery to remove it.
    • Once new battery is placed into the slot, press down on battery until you hear a “click”.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 11
Letzten 30 Tage: 75
Insgesamt: 2,376
