Zum Hauptinhalt wechseln
Einleitung
If you find yourself needing to replace your HP Beats Special Edition 15-p390nr fans, use this guide to help you go through the process successfully.
  1. Turn computer off before starting. Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
    • Turn computer off before starting.
    • Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
  2. Some screws may be hidden under a screw cover. Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Some screws may be hidden under a screw cover.
    • Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Screw cover may fly when removing.
  3. Once screws are removed you may now remove the optical drive. Remove the hidden 3mm screw in the optical drive port.
    • Once screws are removed you may now remove the optical drive.
    • Remove the hidden 3mm screw in the optical drive port.
  4. Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws. Popping noises are normal.
    • Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
    • Popping noises are normal.
    • The shoulder caps are removable. Underneath there are 2 additional screws.
  5. Flip computer over and wedge metal spudger along the computer to pop off keyboard panel Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
    • Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
  6. Unclip wires connected to the motherboard and remove keyboard from the device. 17 screws should be removed up to this point.
    • Unclip wires connected to the motherboard and remove keyboard from the device.
    • 17 screws should be removed up to this point.
  7. Remove screws from the motherboard.
    • Remove screws from the motherboard.
    • 11 screws should be removed from the motherboard
  8. Unclamp wire strips from motherboard.
    • Unclamp wire strips from motherboard.
  9. Detach by lifting the motherboard up and flip the motherboard over.
    • Detach by lifting the motherboard up and flip the motherboard over.
  10. Unclip wifi card for further procedures
    • Unclip wifi card for further procedures
  11. Remove the fan cable from the connector that connects to the motherboard.
    • Remove the fan cable from the connector that connects to the motherboard.
    • Pull straight out to avoid damage to connectors.
  12. Remove all three screws that hold the fan to the system board
    • Remove all three screws that hold the fan to the system board
  13. Lift and remove the fan from the top cover.
    • Lift and remove the fan from the top cover.
Abschluss
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 40
Insgesamt: 1,415
