Zum Hauptinhalt wechseln
Einleitung
Use this guide to help disassemble the keyboard panel for any parts needing to be replaced located under the keyboard panel.
  1. Turn computer off before starting. Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
    • Turn computer off before starting.
    • Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
  2. Some screws may be hidden under a screw cover. Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Some screws may be hidden under a screw cover.
    • Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Screw cover may fly when removing.
  3. Once screws are removed you may now remove the optical drive. Remove the hidden 3mm screw in the optical drive port.
    • Once screws are removed you may now remove the optical drive.
    • Remove the hidden 3mm screw in the optical drive port.
  4. Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws. Popping noises are normal.
    • Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
    • Popping noises are normal.
    • The shoulder caps are removable. Underneath there are 2 additional screws.
  5. Flip computer over and wedge metal spudger along the computer to pop off keyboard panel Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
    • Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
  6. Unclip wires connected to the motherboard and remove keyboard from the device. 17 screws should be removed up to this point.
    • Unclip wires connected to the motherboard and remove keyboard from the device.
    • 17 screws should be removed up to this point.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 5
Letzten 30 Tage: 29
Insgesamt: 1,560
