Zum Hauptinhalt wechseln
HP Chromebook 14-x013dx Motherboard Replacement
Was du brauchst
  1. HP Chromebook  14-x013dx Motherboard Replacement, Keyboard, Touchpad: Schritt 1, Bild 1 von 2 HP Chromebook  14-x013dx Motherboard Replacement, Keyboard, Touchpad: Schritt 1, Bild 2 von 2
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook  14-x013dx Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook  14-x013dx Motherboard Replacement: Schritt 3, Bild 1 von 2 HP Chromebook  14-x013dx Motherboard Replacement: Schritt 3, Bild 2 von 2
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook  14-x013dx Motherboard Replacement: Schritt 4, Bild 1 von 2 HP Chromebook  14-x013dx Motherboard Replacement: Schritt 4, Bild 2 von 2
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook  14-x013dx Motherboard Replacement: Schritt 5, Bild 1 von 3 HP Chromebook  14-x013dx Motherboard Replacement: Schritt 5, Bild 2 von 3 HP Chromebook  14-x013dx Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook  14-x013dx Motherboard Replacement, Battery: Schritt 6, Bild 1 von 2 HP Chromebook  14-x013dx Motherboard Replacement, Battery: Schritt 6, Bild 2 von 2
    • Remove the eight 4mm screws holding the battery in place using the Phillips #00 screwdriver.
  7. HP Chromebook  14-x013dx Motherboard Replacement: Schritt 7, Bild 1 von 2 HP Chromebook  14-x013dx Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Remove the ribbon cable that runs over the battery by lifting up the plastic latches and pulling the cable away.
  8. HP Chromebook  14-x013dx Motherboard Replacement: Schritt 8, Bild 1 von 2 HP Chromebook  14-x013dx Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Unhook the battery's power connector from the motherboard.
  9. HP Chromebook  14-x013dx Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Lift the battery out of the laptop case.
  10. HP Chromebook  14-x013dx Motherboard Replacement, Motherboard: Schritt 10, Bild 1 von 3 HP Chromebook  14-x013dx Motherboard Replacement, Motherboard: Schritt 10, Bild 2 von 3 HP Chromebook  14-x013dx Motherboard Replacement, Motherboard: Schritt 10, Bild 3 von 3
    • Carefully remove the 4 connections.
  11. HP Chromebook  14-x013dx Motherboard Replacement: Schritt 11, Bild 1 von 3 HP Chromebook  14-x013dx Motherboard Replacement: Schritt 11, Bild 2 von 3 HP Chromebook  14-x013dx Motherboard Replacement: Schritt 11, Bild 3 von 3
    • Using a Phillips #00 screwdriver, remove the seven 2mm screws holding the motherboard in place.
    • Gently lift the motherboard out of the laptop case.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Eile Woeltje
304 Reputation
2 Anleitungen geschrieben
IUPUI, Team S1-G3, Stella Fall 2019 Mitglied von IUPUI, Team S1-G3, Stella Fall 2019
IUPUI-STELLA-F19S1G3
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 550
