Einleitung
This guide walks through replacing a faulty camera. It requires removing the keyboard mount and lid. Afterwards, this guide requires a plastic opening tool and recommends tweezers to finish removal.
Was du brauchst
Flip the laptop upside down so that the lid lies flat on the table.
Remove the nine 6mm Phillips #00 screws that line the border.
Remove the two rubber feet closest to the hinge using tweezers.
Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
Flip the laptop so it is in the upright position.
Open the lid.
Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
Tilt the keyboard mount up.
Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
Gently remove both ribbon cables.
Gently tug on the black and white wires connected to the Wi-Fi module to disconnect them.
Using a spudger, lift the ZIF retaining flap that secures the display’s ribbon cable to the motherboard.
Gently pull the ribbon cable out of its socket.
Remove the two 6mm Phillips #00 screws located near the upper left and right corners of the hinge mounts.
Rotate the lid to a 90-degree angle with the table.
Shimmy the lid out of the laptop.
Use the plastic opening tool to pry the left and right side of the top of the lid, and proceed inwards from the sides.
Gently remove the slide-out connector near the bottom left corner of the camera mount.
Locate the two silver strips of tape on each edge of the camera mount.
Use tweezers to peel off these strips.
3 weitere Personen haben diese Anleitung absolviert.
