Einleitung
The guide walks through replacing a faulty motherboard. It requires removing the keyboard mount. Afterwards, it is relatively simple and requires only a Phillips head screwdriver and spudger to finish removal.
Flip the laptop upside down so that the lid lies flat on the table.
Remove the nine 6mm Phillips #00 screws that line the border.
Remove the two rubber feet closest to the hinge using tweezers.
Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
Flip the laptop so it is in the upright position.
Open the lid.
Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
Tilt the keyboard mount up.
Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
Gently remove both ribbon cables.
Gently pull the battery’s rainbow-colored, bundled cable out of its socket.
Use a spudger to lift the small ZIF retaining flap for the ribbon cable that connects the SD card reader to the motherboard.
Gently pull the cable out of its socket.
Remove the 2 mm Phillips #00 screw that holds the Wi-Fi module in place.
Slide the Wi-Fi module out of the motherboard.
Gently pull the bundled cable that connects the charging port to the motherboard out of its connector on the motherboard.
Use a spudger to lift the small ZIF retaining flip for the ribbon cable that connects the display to the motherboard.
Gently slide the motherboard to the left and away from the external ports on the right and then pull it up and out of the laptop.
Ein weiterer Nutzer hat diese Anleitung absolviert.
