Zum Hauptinhalt wechseln
Einleitung
This guide walks through replacing a faulty SD card reader module. It requires removing the keyboard mount. Afterwards, it is relatively simple and requires only a Phillips head screwdriver and a spudger to finish removal.
  1. Flip the laptop upside down so that the lid lies flat on the table. Remove the nine 6mm Phillips #00 screws that line the border.
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. Remove the two rubber feet closest to the hinge using tweezers. Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. Flip the laptop so it is in the upright position.
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. Tilt the keyboard mount up. Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard. Gently remove both ribbon cables.
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. Lift the keyboard mount out of the laptop.
    • Lift the keyboard mount out of the laptop.
  6. On the module, use a spudger to lift the small ZIF retaining flap for the ribbon cable connecting the SD card reader to the motherboard. Gently pull the ribbon cable out of its socket.
    • On the module, use a spudger to lift the small ZIF retaining flap for the ribbon cable connecting the SD card reader to the motherboard.
    • Gently pull the ribbon cable out of its socket.
  7. Remove the two Phillips #00 6mm screws that attach the module to the laptop.
    • Remove the two Phillips #00 6mm screws that attach the module to the laptop.
  8. Lift the module up and out of the laptop.
    • Lift the module up and out of the laptop.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Rahul Goyal
1.369 Reputation
10 Anleitungen geschrieben
Cal Poly, Team S23-G3, Livingston Spring 2017 Mitglied von Cal Poly, Team S23-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G3
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 3
Insgesamt: 248
