Einleitung
This guide will walk you through how to replace the SD card reader on the HP Chromebook 11 G4. Once you remove the keyboard, the SD card reader is a cinch to replace.
Was du brauchst
Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
Pry off the rubber pads to reveal a screw under each pad.
Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
Slide the spudger along the gap, applying downward pressure to separate the two components.
Lift the bottom of the keyboard assembly to reveal the internal components of the device.
Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
Flip up the flap on the ZIP connector with your finger.
Gently pull out the ribbon cable.
2 weitere Personen haben diese Anleitung absolviert.
