Einleitung
The Wi-Fi card is what allows the HP Chromebook 11 G4 to connect to the internet through a wireless connection. However, if the Chromebook does not read a connection to the Wi-Fi card, then it needs to be replaced.
Was du brauchst
Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
Pry off the rubber pads to reveal a screw under each pad.
Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
Slide the spudger along the gap, applying downward pressure to separate the two components.
Lift the bottom of the keyboard assembly to reveal the internal components of the device.
Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
Gently slide out the Wi-Fi card away from the motherboard by gripping the edges with your thumb and index finger.
Eine weitere Person hat diese Anleitung absolviert.
