Zum Hauptinhalt wechseln
HP Chromebook 11 G5 EE DC IN Port Replacement
Was du brauchst
  1. HP Chromebook 11 G5 EE DC IN Port Replacement, Removing Palmrest Screws: Schritt 1, Bild 1 von 1
    • Remove the black rubber screw covers using the point of your spudger. Then, remove the 10 #0 Phillips screws from the palmrest.
    • There are no screws under the 4 large rubber feet. Do not remove them.
  2. HP Chromebook 11 G5 EE DC IN Port Replacement, Disengaging Palmrest Clips: Schritt 2, Bild 1 von 1
    • Open the Chromebook at a 90 degree angle, and set it on it's side.
    • Some Chromebooks turn on automatically when opened. If the device turns on, make sure you power it off before proceeding.
    • Insert the spudger into the gap in between the glossy keyboard bezel and the rubbery side part. Gently pry to release the clips. Move the spudger around the perimeter of the device, releasing clips as you go.
    • Make sure you do not allow the palmrest to come detached once all clips are removed, there are fragile ribbon cables attached to it.
  3. HP Chromebook 11 G5 EE DC IN Port Replacement, Disconnect Touchpad Ribbons: Schritt 3, Bild 1 von 3 HP Chromebook 11 G5 EE DC IN Port Replacement, Disconnect Touchpad Ribbons: Schritt 3, Bild 2 von 3 HP Chromebook 11 G5 EE DC IN Port Replacement, Disconnect Touchpad Ribbons: Schritt 3, Bild 3 von 3
    • Lift up the locking tabs on the system board for both ribbons
    • As you lift the palmrest up, the ribbon for the touchpad (white in my case) will be sticking to the bottom of the palmrest with adhesive. Carefully pull the ribbon off so that you can reach in there.
    • Disconnect both ribbons from the system board.
    • Lift up the palmrest and set it off to the side.
  4. HP Chromebook 11 G5 EE DC IN Port Replacement, Remove screws: Schritt 4, Bild 1 von 2 HP Chromebook 11 G5 EE DC IN Port Replacement, Remove screws: Schritt 4, Bild 2 von 2
    • Remove the 3 smaller screws on the system board
    • Remove the one larger silver screw on the system board.
    • Remove the screw holding thew WiFi card in place.
    • Remove the screw holding the battery in place.
  5. HP Chromebook 11 G5 EE DC IN Port Replacement, Disconnect system board: Schritt 5, Bild 1 von 3 HP Chromebook 11 G5 EE DC IN Port Replacement, Disconnect system board: Schritt 5, Bild 2 von 3 HP Chromebook 11 G5 EE DC IN Port Replacement, Disconnect system board: Schritt 5, Bild 3 von 3
    • Disconnect the 4 ribbons pictured that are connecting to the system board
  6. HP Chromebook 11 G5 EE DC IN Port Replacement, Remove screen: Schritt 6, Bild 1 von 2 HP Chromebook 11 G5 EE DC IN Port Replacement, Remove screen: Schritt 6, Bild 2 von 2
    • Remove the 4 screws holding the hinges to the frame. Be careful that when you loosen them, the screen doesn't fall.
    • Once the screws are removed, carefully close the chromebook until it is only open at around a 20 degree angle, make sure the ribbon will not get caught, and slide the screen off of the Chromebook.
    • Set the screen off to the side.
  7. HP Chromebook 11 G5 EE DC IN Port Replacement, Remove system board and battery: Schritt 7, Bild 1 von 3 HP Chromebook 11 G5 EE DC IN Port Replacement, Remove system board and battery: Schritt 7, Bild 2 von 3 HP Chromebook 11 G5 EE DC IN Port Replacement, Remove system board and battery: Schritt 7, Bild 3 von 3
    • Locate the plastic clips/tabs that are holding the system board down. There are 2. One by the battery and one by the left-side hinge.
    • Carefully lift upward from the right-side the battery/system board all at the same time. You will need to lift it up and press in the first tab, and pull it out to the right.
    • Set the system board and battery off to the side.
  8. HP Chromebook 11 G5 EE DC IN Port Replacement, Replace dc in cable: Schritt 8, Bild 1 von 3 HP Chromebook 11 G5 EE DC IN Port Replacement, Replace dc in cable: Schritt 8, Bild 2 von 3 HP Chromebook 11 G5 EE DC IN Port Replacement, Replace dc in cable: Schritt 8, Bild 3 von 3
    • The DC IN cable will be stuck to the bottom assembly with adhesive. Peel up the cable.
    • Remove the screw holding the DC IN cable in place.
    • Connect the new replacement DC IN cable.
    • Cut a piece of packing tape and use it to tape the replacement DC In cable to to the bottom plastic assembly.
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
Chris Storer
352 Reputation
1 Anleitung geschrieben
2 Kommentare
Hi there, nice guide but you can get away with not taking off the entire screen just unscrew the left hinge while the lid is at a 90 degree angle and simply fold flat to have access at the screw holding the DC jack in place
Marco Curry - Antwort
My Hp 11 G5 has a silver palmrest on it and the bottom half of the casing isn’t rubberized. I’ve use my plastic pry tool popping the clips round the case after removing the screws from the underside of the case. I however cannot get the palmrest / keyboard to release. It’s as if it’s still screwed in or glued , a lot. (Yes, I removed ALL the screws from the underside of the casing, including the ones under the rubber plugs {not the rubber feet})
How should I proceed?
Stephen Thompson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 24
Insgesamt: 2,285
