Was du brauchst
Remove the screws from the bottom case.
Two M2.5x8 PH1 screws.
Six M2.5x6 PH1 screws.
Use a plastic opening pick to release the clips that secure the keyboard.
Lift up the keyboard part way, being careful to not put stress on the keyboard and touchpad ribbon cables.
Disconnect the keyboard ZIF connector
Lift up the plastic guard covering the three PH0 M2x2 screws and remove them.
Lift the touchpad out and place into new keyboard.
Peel back the tape over the battery connector, and use a spudger or your fingernails to pull the connector out.
Peel back the tape covering the LVDS cable
Grasp the cable with tweezers or your fingers and pull it gently toward the screen. Avoid pulling upward, as this connector can be fragile.
Use a plastic spudger to separate the protective plastic from the motherboard, which will make the next few steps much easier.
Lift up the arm on the back side of the ZIF connector holding the daughterboard ribbon cables in place.
If done correctly, the cables should pull out of their socket without any force.
Gently use a spudger to lift the antenna cables out of their sockets.
Remove the M2x2.5 PH0 screw holding the wifi card in place
Pull the wifi card straight away from the motherboard. Do not pull up on it.
Fingernails tend to work best, as this connector doesn't like coming loose. A spudger theoretically should work too.
Pull on the cable straight away from the motherboard. Tools generally are not very effective on this connector, and have a high chance of damaging it. Pull gently, and all should be fine.
Grasp the motherboard by the wifi card socket and pull it out of the system.
2 weitere Personen haben diese Anleitung absolviert.
