Zum Hauptinhalt wechseln
HP Chromebook 11 G6 EE Speakers Replacement
Was du brauchst
  1. HP Chromebook 11 G6 EE Speakers Replacement, Remove keyboard screws: Schritt 1, Bild 1 von 1
    • Remove the screws from the bottom case.
    • Two M2.5x8 PH1 screws.
    • Six M2.5x6 PH1 screws.
  2. HP Chromebook 11 G6 EE Speakers Replacement, Remove keyboard: Schritt 2, Bild 1 von 2 HP Chromebook 11 G6 EE Speakers Replacement, Remove keyboard: Schritt 2, Bild 2 von 2
    • Use a plastic opening pick to release the clips that secure the keyboard.
    • Avoid too much prying force. If you pry too hard, you'll break your pick. The trick is to get the pick in just a little bit, and then run it along the edge of the device.
    • DO NOT use metal tools for this step.
  3. HP Chromebook 11 G6 EE Speakers Replacement, Disconnect keyboard: Schritt 3, Bild 1 von 1
    • Lift up the keyboard part way, being careful to not put stress on the keyboard and touchpad ribbon cables.
  4. HP Chromebook 11 G6 EE Speakers Replacement, Disconnect keyboard: Schritt 4, Bild 1 von 3 HP Chromebook 11 G6 EE Speakers Replacement, Disconnect keyboard: Schritt 4, Bild 2 von 3 HP Chromebook 11 G6 EE Speakers Replacement, Disconnect keyboard: Schritt 4, Bild 3 von 3
    • Disconnect the keyboard ZIF connector
  5. HP Chromebook 11 G6 EE Speakers Replacement, Disconnect touchpad: Schritt 5, Bild 1 von 2 HP Chromebook 11 G6 EE Speakers Replacement, Disconnect touchpad: Schritt 5, Bild 2 von 2
    • Disconnect touchpad ZIF connector.
    • Now you can remove the keyboard assembly completely.
    • If your replacement keyboard came with touchpad and cable, you can start reassembling the computer now. If you need to retrieve the touchpad from the old keyboard, keep reading.
  6. HP Chromebook 11 G6 EE Speakers Replacement, Remove touchpad: Schritt 7, Bild 1 von 1
    • Lift up the plastic guard covering the three PH0 M2x2 screws and remove them.
    • Lift the touchpad out and place into new keyboard.
    • Be sure to evenly tighten the touchpad screws during reinstallation. Even a small variance can lead to a touchpad that feels "off".
  7. HP Chromebook 11 G6 EE Speakers Replacement, Speakers: Schritt 8, Bild 1 von 2 HP Chromebook 11 G6 EE Speakers Replacement, Speakers: Schritt 8, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the two 7 mm screws from both sides of each speaker unit.
    • Lift the speakers from the laptop frame.
Abschluss
To reassemble your device, follow these instructions in reverse order. Taking the battery out is optional but we have included it as a reference.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 102
