Einleitung
This is a prerequisite guide that will provide steps to removing the bezel of a HP Chromebook 11 G8 EE. This guide allows you to remove the black plastic display bezel in order to reach the screen and its wiring.
Was du brauchst
Use a Phillips #1 screwdriver to remove:
Four 7 mm screws.
Two 8 mm screws.
Flip the device over and open the lid.
Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
Lift the keyboard assembly from the laptop towards you, away from the screen.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
