Einleitung
The motherboard is the primary piece of circuitry that helps keep your laptop running. After troubleshooting through the possible issues with the motherboard and determining that it needs a replacement, you can follow these steps in order to accomplish that goal. This guide will walk you through the steps of replacing the motherboard in your HP Chromebook 11 G8 EE.
Note that there are many symptoms to a failing motherboard such as a loose connection that is a lot less costly than a replacement.
Was du brauchst
Use a Phillips #1 screwdriver to remove:
Four 7 mm screws.
Two 8 mm screws.
Flip the device over and open the lid.
Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
Lift the keyboard assembly from the laptop towards you, away from the screen.
Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
Lift the lock bar and use tweezers to remove the touchpad ribbon.
Remove the keyboard.
Peel back the film over the speaker's motherboard connector.
Disconnect the speaker cable from the connector on the motherboard.
Remove the four 3.5 mm screws from the base enclosure with a Phillips #1 screwdriver.
Disconnect the battery cable from the motherboard by pulling the connector straight out of its motherboard port.
Unscrew the single screw securing the Wi-Fi card/cover using a Phillips #1 screwdriver.
Remove wireless antenna cables from the module using tweezers.
Pull the Wi-Fi card out from its motherboard port using tweezers.
Flip the two black lock bars on the ZIF connectors using tweezers.
Disconnect both ribbon cables from the motherboard using the tweezers.
Peel back the film and lift the lock bar on the display panel cable with tweezers.
Disconnect the display panel connector with tweezers.
Remove the six 3.5 mm screws with a Phillips #1 screwdriver.
Lift the USB-C bracket off the motherboard.
