Zum Hauptinhalt wechseln
HP Chromebook 11 G8 EE Speaker Replacement
Was du brauchst
  1. HP Chromebook 11 G8 EE Speaker Replacement, Keyboard & Touchpad Assembly: Schritt 1, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
  2. HP Chromebook 11 G8 EE Speaker Replacement: Schritt 2, Bild 1 von 2 HP Chromebook 11 G8 EE Speaker Replacement: Schritt 2, Bild 2 von 2
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
  3. HP Chromebook 11 G8 EE Speaker Replacement: Schritt 3, Bild 1 von 3 HP Chromebook 11 G8 EE Speaker Replacement: Schritt 3, Bild 2 von 3 HP Chromebook 11 G8 EE Speaker Replacement: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
  4. HP Chromebook 11 G8 EE Speaker Replacement, Speaker: Schritt 4, Bild 1 von 2 HP Chromebook 11 G8 EE Speaker Replacement, Speaker: Schritt 4, Bild 2 von 2
    • Peel back the film over the speaker's motherboard connector.
    • Disconnect the speaker cable from the connector on the motherboard.
  5. HP Chromebook 11 G8 EE Speaker Replacement: Schritt 5, Bild 1 von 2 HP Chromebook 11 G8 EE Speaker Replacement: Schritt 5, Bild 2 von 2
    • Unseat the speaker cable from the routing channel of the battery.
  6. HP Chromebook 11 G8 EE Speaker Replacement: Schritt 6, Bild 1 von 1
    • Remove the four 3.5 mm screws from the base enclosure with a Phillips #1 screwdriver.
  7. HP Chromebook 11 G8 EE Speaker Replacement: Schritt 7, Bild 1 von 3 HP Chromebook 11 G8 EE Speaker Replacement: Schritt 7, Bild 2 von 3 HP Chromebook 11 G8 EE Speaker Replacement: Schritt 7, Bild 3 von 3
    • Lift the speakers off the base alignment pins to remove.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Julia Latura
328 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 Mitglied von UMass Dartmouth, Team 4-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G2
5 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 163
