Einleitung
If you are experiencing poor audio quality, first check the device's troubleshooting page. Then if you determine that the speaker's malfunction is a problem with the hardware, this guide is for you. A guide on how to replace your HP Chromebook 11 G8 EE's speakers. Before beginning this process make sure to power off your device and remove disconnect it from its charger.
Was du brauchst
Use a Phillips #1 screwdriver to remove:
Four 7 mm screws.
Two 8 mm screws.
Flip the device over and open the lid.
Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
Lift the keyboard assembly from the laptop towards you, away from the screen.
Peel back the film over the speaker's motherboard connector.
Disconnect the speaker cable from the connector on the motherboard.
Remove the four 3.5 mm screws from the base enclosure with a Phillips #1 screwdriver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
