Zum Hauptinhalt wechseln
HP Chromebook 11-2210nr LCD Screen Replacement
Was du brauchst
  1. HP Chromebook 11-2210nr LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove adhesive tabs using fine point tweezers or a metal spudger.
    • These adhesives are typically located at the bottom left and right corners of the screen.
  2. HP Chromebook 11-2210nr LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the one 3 mm screw located underneath both adhesive layers using a Phillips #0 screwdriver.
  3. HP Chromebook 11-2210nr LCD Screen Replacement: Schritt 3, Bild 1 von 2 HP Chromebook 11-2210nr LCD Screen Replacement: Schritt 3, Bild 2 von 2
    • Using a metal spudger, gently pry the front plastic frame (or bezel) off of the device by inserting the tool along the inside edge of the bezel.
    • Completely open the screen as far as possible to remove the bottom edge of the bezel from the laptop.
    • Be sure to disconnect the bezel from all the way around the screen before completely removing.
  4. HP Chromebook 11-2210nr LCD Screen Replacement: Schritt 4, Bild 1 von 2 HP Chromebook 11-2210nr LCD Screen Replacement: Schritt 4, Bild 2 von 2
    • Remove the four black 3 mm screws along the left and right sides of the LCD screen using a Phillips #0 screwdriver.
  5. HP Chromebook 11-2210nr LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • After removing all screws, gently lower the LCD screen onto the keyboard.
    • The LCD screen will not be completely disconnected from the laptop just yet.
  6. HP Chromebook 11-2210nr LCD Screen Replacement: Schritt 6, Bild 1 von 2 HP Chromebook 11-2210nr LCD Screen Replacement: Schritt 6, Bild 2 von 2
    • Gently use the spudger to pry off the tape on top of the gold chip. You may also use your hands to gently remove the tape.
  7. HP Chromebook 11-2210nr LCD Screen Replacement: Schritt 7, Bild 1 von 2 HP Chromebook 11-2210nr LCD Screen Replacement: Schritt 7, Bild 2 von 2
    • Remove the display cable by gently sliding out the cable away from the LCD screen.
    • This action disconnects the LCD screen from the rest of the device, allowing it to be completely removed.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Sam Houston State, Team S11-G3, Blackburne Fall 2018 Mitglied von Sam Houston State, Team S11-G3, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S11G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 334
