Zum Hauptinhalt wechseln
HP Chromebook 11-2210nr Speakers Replacement
Was du brauchst
  1. HP Chromebook 11-2210nr Speakers Replacement, Speakers: Schritt 1, Bild 1 von 2 HP Chromebook 11-2210nr Speakers Replacement, Speakers: Schritt 1, Bild 2 von 2
    • Position your closed laptop face down to remove the 9 visible 6mm screws using the Phillips #1 screwdriver.
  2. HP Chromebook 11-2210nr Speakers Replacement: Schritt 2, Bild 1 von 3 HP Chromebook 11-2210nr Speakers Replacement: Schritt 2, Bild 2 von 3 HP Chromebook 11-2210nr Speakers Replacement: Schritt 2, Bild 3 von 3
    • Using the metal spudger, remove the two rubber pads that are closer to the hinge of the laptop.
    • Remove the two additional 6mm screws located beneath the rubber pads using the Phillips #1 screwdriver.
    • The two bottom rubber pads do not contain screws, but you may check if you wish to be sure.
  3. HP Chromebook 11-2210nr Speakers Replacement: Schritt 3, Bild 1 von 3 HP Chromebook 11-2210nr Speakers Replacement: Schritt 3, Bild 2 von 3 HP Chromebook 11-2210nr Speakers Replacement: Schritt 3, Bild 3 von 3
    • Turn the Laptop over and with the metal spudger start to run it along the plastic seam to pry it off.
    • You will hear popping sounds when you are sliding the spudger along the device.
    • For an easier removal, start from the sides and work your way in to the corners.
  4. HP Chromebook 11-2210nr Speakers Replacement: Schritt 4, Bild 1 von 3 HP Chromebook 11-2210nr Speakers Replacement: Schritt 4, Bild 2 von 3 HP Chromebook 11-2210nr Speakers Replacement: Schritt 4, Bild 3 von 3
    • Carefully lift off the keyboard and gently place it towards you until the two ZIF ribbon wires become visible and place the keyboard down.
    • Locate where the two ZIF ribbon wires are connecting the keyboard to the motherboard in place by clasps.
    • This does not disconnect the keyboard from the laptop just yet.
  5. HP Chromebook 11-2210nr Speakers Replacement: Schritt 5, Bild 1 von 3 HP Chromebook 11-2210nr Speakers Replacement: Schritt 5, Bild 2 von 3 HP Chromebook 11-2210nr Speakers Replacement: Schritt 5, Bild 3 von 3
    • Using the nylon spudger, lift the plastic clasps holding the two ribbon wires up to properly disconnect the wires.
    • It is recommended to use the nylon spudger for this step. Any metal can damage your motherboard.
    • This step completely disconnects the keyboard to allow safe removal and replacement.
  6. HP Chromebook 11-2210nr Speakers Replacement: Schritt 6, Bild 1 von 2 HP Chromebook 11-2210nr Speakers Replacement: Schritt 6, Bild 2 von 2
    • Remove the six 4mm screws holding the battery in place with a Phillips #1 screwdriver.
  7. HP Chromebook 11-2210nr Speakers Replacement: Schritt 7, Bild 1 von 3 HP Chromebook 11-2210nr Speakers Replacement: Schritt 7, Bild 2 von 3 HP Chromebook 11-2210nr Speakers Replacement: Schritt 7, Bild 3 von 3
    • Carefully unplug the bundle power cable by pulling both edges towards you.
    • This successfully disconnects the battery from the laptop.
  8. HP Chromebook 11-2210nr Speakers Replacement: Schritt 8, Bild 1 von 3 HP Chromebook 11-2210nr Speakers Replacement: Schritt 8, Bild 2 von 3 HP Chromebook 11-2210nr Speakers Replacement: Schritt 8, Bild 3 von 3
    • Carefully lift the battery and safely remove it out of the laptop.
    • The battery may have an adhesive sticker attached to the bottom. If so, apply more force when lifting it up.
    • After the removal of the battery, the speakers will become accessible.
  9. HP Chromebook 11-2210nr Speakers Replacement: Schritt 9, Bild 1 von 3 HP Chromebook 11-2210nr Speakers Replacement: Schritt 9, Bild 2 von 3 HP Chromebook 11-2210nr Speakers Replacement: Schritt 9, Bild 3 von 3
    • Use the metal spudger to release the LEFT speakers from the laptop.
    • Use the metal spudger to release the RIGHT speaker from the laptop.
    • The two speakers are connected to a wire that runs along the bottom edge of the laptop and connected up to the motherboard.
  10. HP Chromebook 11-2210nr Speakers Replacement: Schritt 10, Bild 1 von 3 HP Chromebook 11-2210nr Speakers Replacement: Schritt 10, Bild 2 von 3 HP Chromebook 11-2210nr Speakers Replacement: Schritt 10, Bild 3 von 3
    • Unplug the speakers small wire bundle from the motherboard.
    • You will notice the speaker wire is pinched between a screw slot and underneath the motherboard.
  11. HP Chromebook 11-2210nr Speakers Replacement: Schritt 11, Bild 1 von 2 HP Chromebook 11-2210nr Speakers Replacement: Schritt 11, Bild 2 von 2
    • Remove the one 4mm screw located above the pinched wire.
  12. HP Chromebook 11-2210nr Speakers Replacement: Schritt 12, Bild 1 von 3 HP Chromebook 11-2210nr Speakers Replacement: Schritt 12, Bild 2 von 3 HP Chromebook 11-2210nr Speakers Replacement: Schritt 12, Bild 3 von 3
    • Using the nylon spudger, slightly pry up the motherboard to release the pinched wire.
    • This step completely disconnects the speaker from the laptop to be safely removed.
Abschluss
Gerardo Cardona
364 Reputation
2 Anleitungen geschrieben
Sam Houston State, Team S11-G3, Blackburne Fall 2018 Mitglied von Sam Houston State, Team S11-G3, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S11G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 8
Insgesamt: 146
