Einleitung
In this guide, you will be able to perform the process of removing and replacing your faulty or broken speakers. Both speakers are connected to a single wire plugged into the motherboard.
Was du brauchst
Position your closed laptop face down to remove the 9 visible 6mm screws using the Phillips #1 screwdriver.
Using the metal spudger, remove the two rubber pads that are closer to the hinge of the laptop.
Remove the two additional 6mm screws located beneath the rubber pads using the Phillips #1 screwdriver.
Turn the Laptop over and with the metal spudger start to run it along the plastic seam to pry it off.
Carefully lift off the keyboard and gently place it towards you until the two ZIF ribbon wires become visible and place the keyboard down.
Locate where the two ZIF ribbon wires are connecting the keyboard to the motherboard in place by clasps.
Using the nylon spudger, lift the plastic clasps holding the two ribbon wires up to properly disconnect the wires.
Remove the six 4mm screws holding the battery in place with a Phillips #1 screwdriver.
Carefully lift the battery and safely remove it out of the laptop.
After the removal of the battery, the speakers will become accessible.
Use the metal spudger to release the LEFT speakers from the laptop.
Use the metal spudger to release the RIGHT speaker from the laptop.
Using the nylon spudger, slightly pry up the motherboard to release the pinched wire.
