Zum Hauptinhalt wechseln
HP Chromebook 11A G8 EE Screen Replacement
Was du brauchst
  1. HP Chromebook 11A G8 EE Screen Replacement, Keyboard Assembly: Schritt 1, Bild 1 von 2 HP Chromebook 11A G8 EE Screen Replacement, Keyboard Assembly: Schritt 1, Bild 2 von 2
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Screen Replacement: Schritt 2, Bild 1 von 3 HP Chromebook 11A G8 EE Screen Replacement: Schritt 2, Bild 2 von 3 HP Chromebook 11A G8 EE Screen Replacement: Schritt 2, Bild 3 von 3
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Screen Replacement: Schritt 3, Bild 1 von 2 HP Chromebook 11A G8 EE Screen Replacement: Schritt 3, Bild 2 von 2
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
  4. HP Chromebook 11A G8 EE Screen Replacement, Bezel: Schritt 4, Bild 1 von 1
    • Pry the hinge cap off with your hands by lifting it up.
  5. HP Chromebook 11A G8 EE Screen Replacement: Schritt 5, Bild 1 von 1
    • Use the iFixit opening tool to pry the bezel up.
  6. HP Chromebook 11A G8 EE Screen Replacement: Schritt 6, Bild 1 von 1
    • Once you have pried away the bezel, pull it up towards you.
    • Peel it off gently from the screen.
  7. HP Chromebook 11A G8 EE Screen Replacement: Schritt 7, Bild 1 von 1
    • You are finished once the bezel is off of the device.
  8. HP Chromebook 11A G8 EE Screen Replacement, Screen: Schritt 8, Bild 1 von 1
    • Remove the four 3.5 mm screws with the Phillips #0 screwdriver.
  9. HP Chromebook 11A G8 EE Screen Replacement: Schritt 9, Bild 1 von 1
    • Flip the screen towards you.
  10. HP Chromebook 11A G8 EE Screen Replacement: Schritt 10, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Once the screen is flipped down, use the tweezers to peel away the black tape holding down the connector.
  11. HP Chromebook 11A G8 EE Screen Replacement: Schritt 11, Bild 1 von 1
    • Next, peel away the tan tape, using the tweezers, exposing the screen connector.
  12. HP Chromebook 11A G8 EE Screen Replacement: Schritt 12, Bild 1 von 1
    • Using the tweezers, remove the connector by the latch attached to it.
  13. HP Chromebook 11A G8 EE Screen Replacement: Schritt 13, Bild 1 von 1
    • Finally, pull away the screen, to remove it from the device.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Kim Travers
523 Reputation
2 Anleitungen geschrieben
University of Alabama, Team 2-1, Bedsole Fall 2021 Mitglied von University of Alabama, Team 2-1, Bedsole Fall 2021
UA-BEDSOLE-F21S2G1
4 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Does IFixit Sell this screen? I am unable to source parts and this screen for these educational units by HP. I wish iFixit would also list the parts that are needed for the repairs and not just the tools they sell.
Glenn Silva - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 26
Letzte 30 Tage: 80
Insgesamt: 3,117
